Old 07-02-2014, 10:22 AM
hfarmer hfarmer is offline
Logging an RT with a window of time
I'm currently trying to get a study set up using vizard 4 and am having a bit of a problem. I want to set up some code to measure reaction times after the presentation of a stimuli. However I want the program to move on to the next trial after 3 seconds regardless of whether a key is pressed or not. However this doesn't seem to be possible using the standard way of measuring reaction times given in the Vizard tutorial e.g:
		d = yield viztask.waitDraw() #Set Display time
		displayTime = d.time #Log display time
		d = yield viztask.waitKeyDown(None) #Log keypress time
		pressTime = d.time
		reactionTime = pressTime- displayTime #Calculate reaction time
Basically I want to know if there's a way to set up two parallel processes, one which is waiting for a key press to log reaction times and the other which just runs a timer and moves on the program after 3 seconds. Any help would be much appreciated.
Old 07-02-2014, 04:48 PM
You can use the viztask.waitAny command to wait for one condition, out of a list of conditions, to occur.
Old 07-07-2014, 02:53 AM
Hi Jeff,
Thanks for your help.
I found that command but the problem is that I want the program to always wait 3 seconds before moving on regardless of whether a key is pressed or not. But it seems like to log the reaction time I need to make if a yield command and that means the program will wait until a key is pressed before moving on. Is there a way to log reaction time without using the yield command?
Best,
Harry
Old 07-07-2014, 03:23 PM
You could log the reaction time and then yield for an additional amount of time equal to 3 seconds minus the reaction time:
import viztask
def MyTask():
	waitKey = viztask.waitKeyDown(' ')
	waitTime = viztask.waitTime(3)
	while True:
		print 'start'
		#Wait for next frame to be drawn to screen
		#Save start time
		startTime = d.time
		d = yield viztask.waitAny( [ waitKey, waitTime ] )
		if d.condition is waitKey:
			keyData = d.data
			elapsed = keyData.time - startTime
			print 'The spacebar was pressed after {:.2f} seconds'.format(elapsed)
			yield viztask.waitTime(3-elapsed)
		elif d.condition is waitTime:
			print '3 seconds passed, the spacebar was not pressed'
viztask.schedule( MyTask() )
Old 07-18-2014, 05:38 AM
Hi Jeff,
Sorry for the delay in getting back to you, thanks for the example code, I didn't know about the condition command before but can see that it would be very useful. However I have one more question which is how to remove the "True" condition after each trial so that the program moves on to the next trial.
At the moment I am getting the information logged but the program seems to stick on the first condition rather than timing out after 3 seconds. Could you let me know what the "while True" part of the code refers to? I assume it just means while in that function but am a bit unclear on how to end the function with a command.
Best,
Harry
Old 07-18-2014, 02:28 PM
The while True line always evaluates to True so the loop keeps repeating. To run that code a set number of times you could use a for loop or have an expression following while that evaluates to False after several loops. Try replacing:
while True
with:
for i in range(1,5):
	print 'start trial {}'.format(i)
Old 07-21-2014, 06:15 AM
Dear Jeff,
Just wanted to let you know that I tried what you suggested and the program works perfectly now.
Many Thanks,
Harry
exact copy of mainview in second window dcnieho Vizard 1 06-30-2014 04:02 PM
Window always on top madeinjava Vizard 4 08-27-2013 02:10 PM
Unexpected Change of Window Size javadi Vizard 7 07-23-2013 02:56 PM
Inconsistent timestamp while logging mape2k Vizard 4 07-15-2013 06:03 AM
