Old 06-23-2014, 04:04 AM
You can have multiple functions registered with different vizact.onupdate and vizact.ontimer commands running at the same time. That maybe all you need for your application. How are you currently calling these functions?
Old 06-23-2014, 07:38 AM
pradeep pradeep is offline
Now i simply try calling the functions using the multiprocessing in actual python code. but it doesn't works. and now i tried using vizmultiprocess but still i dono how to use it exactly. The blinkdetection() and regionofinterest() are my two functions which has to be run independently from each other and it should start at same time and end at same time when i try to execute where the blinkdetection() function has to run at the background. Is it possible to do here.
Old 06-24-2014, 12:09 AM
Post
Even i tried with ontimer() function as given in help document of vizard. But i cant get any output from that. It was simply static
def Blink_Detection()
print 'inside blink detection function'
some process...........
vizact.ontimer2(3,3,Blink_Detection)
but this code does not give any output. Could you please correct me where i should change my mistakes in the code. And also help me to add another function along with my code (say RegionofInterest())
thank you,
Old 06-25-2014, 03:21 AM
Can the scenario what i try to tell can be possible. If so please kindly help telling me as early as possible. I m struck out with my work because of this....
Thank you.
multiprocessing, vizmultiprocess
Multiprocessing Process sleiN13 Vizard 2 08-01-2011 04:47 AM
