Old 03-19-2014, 08:28 AM
fordprefect fordprefect is offline
Exclamation IDE file path resolution with 'Go To Definition' (bug)
First to say:
IDE warning when a loaded module obscures another module (with same name) on the search path
new middle-click shortcut for Go To Definition option from the context menu
Next: when executing a script, references to imports are solved by
  1. looking in the script's folder
  2. looking in the Vizard library folder c:\Program Files\WorldViz\Vizard5\python\
  3. looking in the Python library folder c:\Program Files\WorldViz\Vizard5\bin\lib\
So far so good.
now for the part: when invoking the Go To Definition command, this search path seems not to be used. More precisely, the file's folder is not searched.
[I found this as, for the moment, I have to obscure the shipped vizproximity module with my fixed variation. And when going for a definition, the IDE would always open the library file, and not mine]
Best Regards, Walter
21 is only half the truth.
bug, ide, path resolution, vizard 5.0
Closing of an imported .py file Uttama_vizard Vizard 2 05-04-2010 07:18 AM
IVEx file extenstion unrecognised. sindi Vizard 2 12-10-2009 02:20 AM
problems with output to a text file within executable Saz Vizard 1 07-01-2009 12:01 PM
File Management Uttama_vizard Vizard 2 07-01-2008 10:44 AM
File Path 4 Object Load softscan2 Vizard 1 09-23-2005 09:59 AM
