Old 03-04-2014, 02:17 AM
Erikvdb Erikvdb is offline
Avatar Material Problem
Hi all,
I'm trying to export an avatar from 3Ds Max to Vizard like I've done many times before, but I'm suddenly having issues with the material. First of all the texture doesn't automatically load, but more annoyingly I get the message:
Warning: Material::setShininess() of 6400 is above permitted maximum, clampping to 128.
Which makes the model very shiny. I cannot figure out what causes this, I've tried all kinds of settings in 3Ds Max, removing spec maps, turning off specular levels all together, but every time, even on files that have previously worked, I get the same problem. Any ideas?
I'm using the latest Cal3D exporter from the Worldviz download page in 3DsMax 2014 64bit.
Old 03-04-2014, 03:46 AM
*Facepalm* Never mind. I forgot I renamed my materials and removed the [0] suffix... Cal3D is pretty specific about that.
The older models I checked were Vizard complete characters which also don't have that set by default (even the 'export ready' ones, which is a bit misleading)
It does make me wonder though: is there a way to affect shininess straight out of the box? Because spec levels and maps don't really seem to make any difference unless I specifically write a shader for them.
.osg biped avatar problem alvinadi Vizard 3 12-20-2011 10:29 AM
Cal3d material problem fracture Vizard 0 09-10-2009 01:58 AM
Avatar speaking problem Uttama_vizard Vizard 4 03-23-2009 11:29 AM
Unable to get material onto 3d Max avatar VDong Vizard 1 03-10-2009 11:45 AM
Problem with letting an avatar face towards another avatar ghazanfar Vizard 2 03-21-2007 02:30 AM
