Old 02-27-2014, 07:57 PM
mikeb mikeb is offline
Creating Realistic Turns in Vizard using walkTo
I'm working on a project where Vizard is being is being used to visualize various everyday walking scenarios.
A camera is linked to an avatar which is being set through these scenarios.
Initially a path was created for the avatar to follow, however the avatar and camera glitch out when turning the corner. Additionally creating a path seems to have issues with climbing non-level terrain such as slopes.
As a result <vizact>.walkTo was implemented which so far has been working perfectly for slopes. The issue with using walkTo seems to be it's difficult to simulate turns using this command.
Is there a method for creating turns using walkTo that doesn't look choppy and creates a relatively clean curve? If not is there a better way to simulate a curve in Vizard?
Currently our code looks like this for the turn
b = range(1,91,10)
print(b)
def right_turn_fcn(initX,initZ,radius):
    theta=float(0)
    for theta in ((b)):
        print theta
        Z_new=initZ+(radius*math.cos(theta/(180.0)*(3.14)))-radius
        X_new=initX+(radius*math.sin(theta/(180.0)*(3.14)))
        print(X_new,Z_new)
        avatar.addAction(vizact.walkTo([X_new,ground,Z_new],walkSpeed=speed,turnSpeed = (theta*speed/(2*radius*math.sin(theta/(2.0))))))
right_turn_fcn(-27,17.5,5)
We have tried playing with the parameter turnSpeed, but so far have not been able to achieve a smooth looking curve. Any direction would be greatly appreciated for mimicking a smooth turn.
Mike
Old 02-28-2014, 05:51 AM
Try linking the avatar to an animation path. If you are using 3ds Max, you can quickly create complex paths that are exported with the model:
http://docs.worldviz.com/vizard5/#ma...tion_paths.htm
You can also create animation paths in Vizard by specifying a series of points:
http://docs.worldviz.com/vizard5/#Animation_paths.htm
Creating a Vizard Sensor Plugin farshizzo Plug-in development 25 08-01-2019 12:24 AM
