Old 01-31-2014, 07:34 AM
Saule Saule is offline
Thanks for the reply Jeff! I've tried this option, and for some reason the new .exe worked on the computer which didn't display it correctly last time (I din't change anything in the code). Unfortionaly, that also means I don't know what the problem was as I don't get any error message now. I'm currently looking for a system where I get the same problem so I can try again.
Somthing else which happens on my laptop (but not any other computer I've tried it on), is that the vizinput.ask box somehow appears behind the vizard screen when I run it. The solution is alt-tab to find it, but that's a bit messy. I've looked at the console, but there are no messages related to the pop-up and no errors. It also doesn't do this every time, which makes it difficult to say what the problem is. I don't know if anyone has ever heard of similar issues?
.exe, not loading, problem, vizard 3
ERROR: Failed to load .ive file turgutm Vizard 1 09-16-2010 06:16 AM
still problem with data from .exe file Saz Vizard 1 07-10-2009 11:12 AM
Vizard file save as .exe urgent!!! tacbob Vizard 2 05-10-2007 02:05 AM
