Old 01-27-2014, 08:49 PM
mikeb mikeb is offline
Saving a variable through network
I'm relatively new to Vizard and was seeking advise on a project I'm working on.
I have a control program written in MatLab which I was hoping to communicate with a Vizard program. Ideally I would like to save a variable that can be used in Vizard which is sent from MatLab. I have become familiar with the basic networking commands and am able to send and retrieve data back and fourth.
For example using the below code I was able to retrieve data from MatLab.
myNetwork = viz.addNetwork('IP here')
myNetwork.port(4950)
def onNetwork(e):
if isinstance(e,viz.RawNetworkEvent):
print e.raw_data
viz.callback(viz.NETWORK_EVENT,onNetwork)
Is there an easy way to save this data as a variable to be used in a Vizard Script?
Thank you for your time, I hope I explained things as clearly as possible and I apologize if this is an extremely basic question.
Old 02-01-2014, 12:48 AM
Hi mikeb,
When starting with Vizard, it's good to ask basic questions, so not worries. What you could try is instead of printing the raw data, you can assign that raw data to a variable in Vizard. I don't now the nature of your raw data, so maybe you need to assign one specific part of the raw data to a variable, but the principle is the same:
def onNetwork(e):
		 your_variable = e.raw_data
For next time, it's better to use the CODE tags around your code to make it more readable. You can get those tags by clicking the hashtag (#) sign in the editing options for your message.
Good luck,
Frank
Display a variable in main graphics window laker Vizard 2 09-17-2013 01:56 PM
Children not accessible after saving to/loading OSGb torbeng Vizard 3 09-12-2013 04:36 AM
pool network tutorial.py did not work Kazutaka Mitobe Vizard 0 05-29-2012 08:24 AM
Labjack U12 and network server license activation sindi Vizard 1 02-26-2010 01:35 PM
Using 5DT plug-in with the data coming through network... mcicek Vizard 1 05-18-2009 06:17 PM
