Can you publish the exe again and check the 'display console' option? When you run the exe you'll probably see error messages in the console that you can post here.
| Tags |
| .exe, not loading, problem, vizard 3 |
| Thread Tools | |
| Display Modes | Rate This Thread |
| ERROR: Failed to load .ive file | turgutm | Vizard | 1 | 09-16-2010 06:16 AM |
| still problem with data from .exe file | Saz | Vizard | 1 | 07-10-2009 11:12 AM |
| Vizard tech tip: Using the Python Imaging Library (PIL) | Jeff | Vizard | 0 | 03-23-2009 12:13 PM |
| Vizard file save as .exe urgent!!! | tacbob | Vizard | 2 | 05-10-2007 02:05 AM |
| Could not find plugin to load objects... | halley | Vizard | 1 | 05-30-2006 12:01 PM |
