Use the arrington plug-in to get gaze point data.
#Create arrington extension
arrington = viz.add('arrington.dle')
#Connect to eye tracker
tracker = arrington.addEyeTracker()
def printData():
#Print smoothed gaze position (default)
print tracker.getPosition()
#Print raw gaze position
print tracker.getPosition(arrington.RAW)
vizact.onupdate(0,printData)
Thank you for your reply Jeff,
I executed the code which is in Arrington plug-in and also send by you and getting the following command... [0.0, 1.0, 0.0] [0.0, 1.0, 0.0] [0.0, 1.0, 0.0] [0.0, 1.0, 0.0] [0.0, 1.0, 0.0] [0.0, 1.0, 0.0].........it is continuously going on and unable to get the real time value of Gaze point. so,give me suggestions to get the value in real time.Thank you for spending time to solve my issue. |
| Thread Tools | |
| Creating a Vizard Sensor Plugin | farshizzo | Plug-in development | 25 | 08-01-2019 12:24 AM |
| Live Characters plugin | Frank Verberne | Vizard | 7 | 03-01-2012 02:23 AM |
| Vicon Plugin | Micheal | Plug-in development | 2 | 08-29-2007 03:03 AM |
| Could not find plugin to load objects... | halley | Vizard | 1 | 05-30-2006 11:01 AM |
| Shooting Star Plugin | duda | Vizard | 3 | 03-14-2005 11:52 AM |
