Old 01-23-2014, 07:24 AM
Saule Saule is offline
Vizard .exe file doesn't load (Vizard 3)
I'm working on a project where we need a vizard (3) application to be run on several different 'at-home' computers (only windows). At the moment, we have the problem that on some computers vizard doesn't start properly. The 'vizard is loading' bar appears just fine, and the .winviz process is running in the background but the program just doesn't show up. It doesn't happen on all computers, and on those where it does the original source code works just fine. (the .exe is made on a different destkop than the ones which have problems). Although I have the source code, it wasn't originally written by me so I don't know the code through and through.
I was wondering if anyone has ever heard of similar issues, or has any idea what the problem could be? I couldn't find an easily identifyable aspect which the different computers have in common, so I have no idea what's causing it.
.exe, not loading, problem, vizard 3
ERROR: Failed to load .ive file turgutm Vizard 1 09-16-2010 06:16 AM
still problem with data from .exe file Saz Vizard 1 07-10-2009 11:12 AM
Vizard file save as .exe urgent!!! tacbob Vizard 2 05-10-2007 02:05 AM
