Old 11-12-2013, 05:18 PM
saajaja saajaja is offline
Blindfolding screen, asking for input, unblindfolding.
Hello, and thank you for reading. Here is what I am trying to do:
1. Turn the screen black.
2. Display a popup dialog which asks for an input.
3. Turn the world back on.
Here is some code that should do that when you press the spacebar:
import vizinput
piazza = viz.add('piazza.osgb')
def getInput():
	# Blindfold. This isn't working.
	viz.MainScene.visible(0,viz.WORLD)
	viz.clearcolor(viz.SKYBLUE)
	# Ask for input
	input = ''
	while input == '':
		input = vizinput.input('Input something.')
	# Unblindfold
	viz.MainScene.visible(1,viz.WORLD)
	viz.clearcolor(viz.BLACK)
vizact.onkeydown(' ', getInput)
However, it does not do that. Instead, it does this:
1. Ask for input.
Help would be greatly appreciated. Thank you for reading.
Old 11-13-2013, 06:15 AM
Hi Saajaja,
The code below should do what you want. Note that the color of the screen will be skyblue instead of black (as stated in your question). Just change SKYBLUE to BLACK to change that. I think the problem is that the function you used immediately shows the input window, before drawing the scene again. By using the module viztask and schedule, you can make Vizard first draw one frame, and then do something else.
import vizinput
import viztask
def getInput():
	# Blindfold.
	yield viztask.waitFrame(1)
	# Ask for input
	input = ''
	while input == '':
	# Unblindfold.
def inputScreen():
	viztask.schedule(getInput)
vizact.onkeydown(' ', inputScreen)
Good luck!
Frank
Old 11-13-2013, 02:44 PM
Thank you, Frank, that works great!
Old 11-13-2013, 09:31 PM
Dear Frank,
I spoke too soon. Your code helped speed me in the right direction, but it had a semantic bug. Execution would continue before the actual input value was received. So if we wanted to actually do anything with the input string, we would end up doing weird stuff that we didn't want to do.
In order to make the program wait for an actual input to arrive from the user, I did some fancy signal stuff based on your code and the two balls example at the bottom of Task Basics.
import vizinput
import viztask
class test:
	def __init__(self):
		self.input = 'initialized value'
		vizact.onkeydown(' ', self.getAndPrintInput)
		self.gotInputSignal = viztask.Signal()
	def getInput(self):
		# Blindfold.
		viz.fogcolor(viz.GRAY)
		viz.fog(.2)
		# Ask for input
		self.input = vizinput.input('Input something.')
		self.gotInputSignal.send()
		# Unblindfold.
		viz.fog(0)
	def printInput(self):
		# Wait for an actual input to arrive.
		yield self.gotInputSignal.wait()
		print self.input
	def getAndPrintInput(self):
		viztask.schedule( self.getInput() )
		viztask.schedule( self.printInput() )
t = test()
I learned a lot today. Thank you for your support!
Old 11-14-2013, 04:18 AM
Hi Saajaja,
Seems like you already figured out how to solve your problem. However, a simpler solution seems like to yield a function, where you do something with the input. Everything that is in that function should be executed before showing the world again. Now, I just print the input and wait a few seconds, so you can see that everything in the function is executed before executing the rest of the code.
import vizinput
import viztask
def printValue(value):
	print value
	viz.waitTime(4)
def getInput():
	# Blindfold.
	# Ask for input
	input = ''
	while input == '':
	yield printValue(input)
	# Unblindfold.
def inputScreen():
Old 11-14-2013, 08:08 AM
That's much better! Thank you very much, Frank.
Screen Size and Scaling javadi Vizard 2 04-02-2013 05:56 PM
Pygame Screen within Vizard World VirtuallyInsane Vizard 4 02-18-2013 09:50 AM
Attach a TexQuad to pit.osgb screen Ducky Vizard 1 01-17-2013 02:57 PM
split screen honey006 Vizard 3 05-21-2009 09:57 AM
position of html-file on screen active_world Vizard 1 05-16-2008 07:24 PM
