Old 11-05-2013, 11:48 AM
then accurate real-time immersive interaction is not possible!
Thank you for the reply farshizzo. Unfortunately, the answer is a bit disappointing. The NVIS line of helmets requires a 60 hz input, and will not function if vsync is turned off, or >60hz. I study human visual-motor behavior, and cannot allow visual tearing in the stimulus.
Until this issue is addressed, accurate real-time immersive interaction is not possible. This is a huge impediment to my own research. I will workaround this issue for as long as I can, but forsee having to switch away from Vizard if this is not eventually addressed.
Please keep me updated!
Thanks again.
motion capture, physics, vertical refresh, vsync
Streaming Motion Capture EnvisMJ Vizard 4 07-06-2010 11:50 AM
Motion Capture & CyberGloves EnvisMJ Vizard 1 10-01-2009 05:21 PM
