Old 10-17-2013, 11:49 AM
dig dig is offline
input from a text file
Hi there
I'm designing an experiment in which I read input values off a text file. The text file has 5 columns, the first two containing numbers and the other 3 Greek words. I use the following code:
s = line.split()
myTrial = [float(s[0]),float(s[1]),s[2],s[3],s[4]]
But, I'm running into a problem. If I save the the text file in ANSI format then the numbers are read correctly but the words when displayed by vizard come up as scrambled characters. If I save the text file in UTF-8 then the text shows up correctly in Greek but then vizard gives me an error when reading the numbers (I know that the text shows up correctly because I tried a text file without the numbers and it works fine).
I don't know much about character encoding so I'm not sure if there is an easy solution to this problem. One option is to have numbers and text in separate text files but this defeats the purpose of my using an input file to simplify experiment design. Any ideas?
Thanks in advance!
marios
Old 10-17-2013, 05:15 PM
Try encoding to ascii before converting to float:
asciidata=s[0].encode("ascii","ignore")
number = float(asciidata)
Old 10-18-2013, 01:03 AM
dig dig is offline
Thanks for the reply Jeff. Unfortunately, it doesn't seem to work (unless I did something stupid of course). Here's my code:
for line in JRDfile:
s = line.split()
asciidata0=s[0].encode("ascii","ignore")
asciidata1=s[1].encode("ascii","ignore")
thisTrial = [float(asciidata0),float(asciidata1),s[2],s[3],s[4]]
JRDTrials.append(thisTrial)
And here's the error message I get:
File "Anthi_JRD.py", line 41, in ?
UnicodeDecodeError: 'ascii' codec can't decode byte 0xef in position 0: ordinal not in range(128)
Note the the text file I'm trying to read from is in UTF-8 format.
Cheers,
marios
Old 10-18-2013, 01:06 AM
dig dig is offline
Just to clarify that indentation in the for loop went away when I copied-pasted from my script. So, there's no problem there.
Old 10-18-2013, 09:36 AM
That code worked for me in Vizard 4 (python 2.7) but produced the same error in Vizard 3 (python 2.4). Are you using Vizard 4?
Old 10-20-2013, 01:20 AM
dig dig is offline
Hi Jeff, I tried it with Vizard 3 at home and got the error message). I have Vizard 4 at the lab, I will try it there on Monday. Thanks!
foreign text, text input
Use saved text file data as replay sources problem mizutani_jun Vizard 4 10-14-2010 04:49 PM
problems with output to a text file within executable Saz Vizard 1 07-01-2009 11:01 AM
How to input several model files and then save one output file mspusch Vizard 1 07-15-2008 10:30 PM
file input vsully Vizard 1 12-21-2004 10:51 PM
I cannot show wrl file with text node sled Vizard 3 06-25-2003 07:52 AM
