  #22
Old 06-09-2005, 05:27 PM
Johannes Johannes is offline
1. Thank you, yes I will try the object.disable(viz.RENDERING)...
2. @ perform an intersect test on each object instead of all at once:
a) If I understand you right you mean something like
info = viz.intersect(ball0503.actualPos.get(), ball0503.nextPos.get())
b) Reason: Because some objects should not trigger an intersection event e.g. ball-traces of other balls...
Would it save CPU-time to do the above and use
if info.object == glider
if info.object != traceBall...
Have a good evening,
Johannes
