Old 10-04-2013, 06:08 AM
sunil.nair sunil.nair is offline
Interaction of vizard objects with an imported obj file
I have imported an obj file in vizard and it loads properly. The issue is when I try to add other objects already present in vizard like ground.wrl, they clash with each other and I am not able to see both of them together.
If I have a car (mini.osg), I am not able to place into the scene contained in the .obj file. No9 matter how I adjust their positions and scale they are separated from each other. Is there a way for the two things to appear together?
Sunil
Old 10-04-2013, 06:39 AM
Just to make it clear, I want my car (mini.osg) to collide with objects contained in my .obj file
Old 10-09-2013, 02:08 PM
Can you post some example code that shows the issue?
Picking up Vizard Objects on mouse down with collisions pwsnow Vizard 2 09-17-2012 02:02 AM
Closing of an imported .py file Uttama_vizard Vizard 2 05-04-2010 06:18 AM
.3DS importing in Vizard and 3D Studio jde Vizard 1 08-28-2009 03:14 PM
