#18
Removed objects and invisible objects cannot trigger intersections. From the code you posted, the only object that can be returned from the intersect call is object. Can you modify your code to the following and see if "WARNING" is printed out? Code:
for object in collidablesBall: info=object.intersect(ball0503.actualPos.get(), ball0503.nextPos.get()) if info.intersected: if info.object != object: print 'WARNING' |
| Thread Tools | |
