Old 09-19-2013, 10:04 AM
When two objects are linked, the destination object (car) will follow after the source (haptic device). If you want the car to follow a different path and go over the cylinder while the device goes through it, don't use a link. You can update the car's X,Z position every frame based on the device position and calculate its Y position based on the intersection of the car and cylinder at that point. To update the car's position every frame register a function with the vizact.onupdate command.
Find collision point of line and arbitrary object asdf Vizard 2 01-28-2013 10:04 AM
Collision Exception jassel41 Vizard 2 11-09-2010 05:08 PM
linked object collision pgagolf Vizard 1 04-19-2007 01:27 PM
when collision mode is on, can i "turn it off" for an individual object? Vdoug Vizard 1 09-22-2005 12:14 PM
Collision Detection often too slow Johannes Vizard 4 02-28-2005 11:11 AM
