Old 09-18-2013, 06:51 PM
thales thales is offline
Render synchronization
Hi everyone!
I'm running an application which requires a tight sychronization with the actual monitor displayed frames. Is there a way to get into the script a start of monitor frame event or a vertical sync flag from the graphic card?
Thank you all,
Thales
Old 09-19-2013, 08:51 AM
The viz.POST_SWAP_EVENT is probably the closest you will get to a vertical sync event, without diving into low-level code. The event is triggered after the frame buffer swap, so it should be essentially right after the monitor vertical sync trigger.
Old 09-19-2013, 11:18 AM
Hi Farshizzo!
Thank you for you fast reply!
I'll try this and be back to tell you how it worked out.
Best,
Thales
actual monitor frames, frame synchronization, vertical sync
Light Baking in 3DS Max causing models to render with seams and transparent faces dproeder Vizard 1 09-17-2013 06:45 PM
Setting up render node for shadowing whaleeee Vizard 2 05-06-2013 10:20 AM
To Masaki regarding render nodes surf3rguy Vizard 1 04-17-2012 05:37 PM
