Old 07-22-2013, 07:56 AM
mape2k mape2k is offline
I am still trying to figure out what the cause of the reduced movement speed in our experiments is.
Jeff, what exactly is the 'Update' time of the renderer? This is the only value that varies during the test runs and also seems to be dependent on the collision:
In the test model of the minimum example I provided, I get update times up to 2 when I enable collision and the movement is slower than it is supposed to be. It stays at 0.1 if I disable collision and the movement speed is correct.
In a standard vizard model (like the one in the minimum example), it is well below 0.3, regardless of collision on or off and the movement speed is correct.
Temporal delay on movement westbyb Vizard 5 05-23-2013 06:06 PM
Varying rotation speed with spinTo mape2k Vizard 2 03-22-2013 07:48 AM
Object + InteriaCube + Viewport problem Gekitatsu Vizard 1 02-22-2012 10:55 AM
random speed and associated coding Saz Vizard 1 05-20-2010 04:03 AM
Calculating Speed with sensor durf Vizard 1 03-13-2009 10:25 AM
