Old 07-10-2013, 02:53 PM
Are there any framerate drops when collision is enabled? Even an occasional drop may affect your calculations. I took a look at your example. I would suggest that you simplify that to the minimum code possible, perhaps just have forward movement in manual mode. I'm not immediately able to see from the log file what the speed or error is. Unless you don't want to publicly post your model, it's best to post everything here so other users can help as well.
Temporal delay on movement westbyb Vizard 5 05-23-2013 07:06 PM
Varying rotation speed with spinTo mape2k Vizard 2 03-22-2013 08:48 AM
Object + InteriaCube + Viewport problem Gekitatsu Vizard 1 02-22-2012 11:55 AM
random speed and associated coding Saz Vizard 1 05-20-2010 05:03 AM
Calculating Speed with sensor durf Vizard 1 03-13-2009 11:25 AM
