I went ahead and attached the model and textures.
Thanks, George Vertex: Code:
#version 120
uniform int NumLights;
varying vec3 vPosition;
varying vec3 tPosition;
varying vec3 tView;
varying vec3 tang;
varying vec3 binorm;
varying vec3 normal;
varying vec3 tLightPosition[gl_MaxLights];
varying vec3 tLightDirection[gl_MaxLights];
attribute vec3 Tangent;
attribute vec3 Binormal;
void main()
//Calculate components in view space
vec3 position = vec3(gl_ModelViewMatrix * gl_Vertex);
normal = normalize(gl_NormalMatrix * gl_Normal);
tang = normalize(gl_NormalMatrix * Tangent);
binorm = normalize(gl_NormalMatrix * Binormal);
mat3 mToTangentSpace = mat3(
tang.x, binorm.x, normal.x,
tang.y, binorm.y, normal.y,
tang.z, binorm.z, normal.z);
tView = mToTangentSpace * (position * -1.0);
tPosition = mToTangentSpace * position;
//Iterate over every light and transition position into tangent space
for( int i = 0 ; i < NumLights ; i++)
tLightPosition[i] = mToTangentSpace * gl_LightSource[i].spotDirection.xyz;
tLightPosition[i] = mToTangentSpace * gl_LightSource[i].position.xyz;
//Pass and transform texture coordinates
gl_TexCoord[0] = gl_TextureMatrix[0] * gl_MultiTexCoord0;
//Pass Perspecitive Coordinates
gl_Position = gl_ModelViewProjectionMatrix * gl_Vertex;
//Compute Fog
gl_FogFragCoord = gl_FogCoord;
#version 120
varying vec3 tView;
varying vec3 tang;
uniform sampler2D Albedo;
uniform sampler2D NormalMap;
uniform sampler2D AmbientOcclusionMap;
//Calculates and returns the contribution of a directional light
void DirectionalLight(in int i,
in vec3 position,
in vec3 view,
in vec3 normal,
inout vec4 ambient,
inout vec4 diffuse,
inout vec4 specular)
float nDotL; //normal dotted with light vector
float nDotH; //normal dotted with half vector
float pf;
nDotL = max(0.0, dot(normal, normalize(tLightPosition[i])));
nDotH = max(0.0, dot(normal, normalize( normalize(tLightPosition[i]) + view) ));
if( nDotL > 0.0)
pf = pow(nDotH, gl_FrontMaterial.shininess);
else
pf = 0.0;
ambient += gl_LightSource[i].ambient;
diffuse += gl_LightSource[i].diffuse * nDotL;
specular += gl_LightSource[i].specular * pf;
//Caculates and returns the contribution of a spotlight
void PointLight( in int i,
in vec3 position,
in vec3 view,
in vec3 iNormal,
inout vec4 ambient,
inout vec4 diffuse,
float nDotL;
float nDotH;
float pf;
float attenuation;
float d;
vec3 LP;
vec3 halfVector;
LP = tLightPosition[i] - position;
d = length(LP); // distance from surface to light for attenuation
vec3 tLP = normalize(tLightPosition[i]);
attenuation = 1.0 / (gl_LightSource[i].constantAttenuation
+ gl_LightSource[i].linearAttenuation * d
+ gl_LightSource[i].quadraticAttenuation * d * d);
halfVector = normalize(tLP + view);
nDotL = max(0.0, dot(iNormal, tLP));
nDotH = max(0.0, dot(iNormal, halfVector));
if (nDotL > 0.0)
else
pf = 0.0;
ambient += gl_LightSource[i].ambient * attenuation;
diffuse += gl_LightSource[i].diffuse * nDotL * attenuation;
specular += gl_LightSource[i].specular * pf * attenuation;
void SpotLight(in int i,
in vec3 position,
in vec3 view,
in vec3 normal,
inout vec4 ambient,
inout vec4 diffuse,
float nDotL;
float nDotH;
float pf;
float spotDot;
float spotAttenuation;
float attenuation;
float d;
vec3 LV;
vec3 halfVector;
LV = tLightPosition[i] - position;
d = length(LV);
LV = normalize(LV);
attenuation = 1.0 / (gl_LightSource[i].constantAttenuation +
gl_LightSource[i].linearAttenuation * d +
spotDot = dot(LV, normalize( tLightDirection[i]));
if(spotDot < gl_LightSource[i].spotCosCutoff)
spotAttenuation = 0.0;
else
spotAttenuation = pow(spotDot, gl_LightSource[i].spotExponent);
attenuation *= spotAttenuation;
halfVector = normalize(LV + view);
nDotL = max(0.0, dot(normal, LV));
nDotH = max(0.0, dot(normal, halfVector));
if(nDotL == 0.0) pf = 0.0;
else pf = pow(nDotH, gl_FrontMaterial.shininess);
void main()
vec4 albedo = texture2D(Albedo , gl_TexCoord[0].xy);
vec3 texNormal = normalize(texture2D(NormalMap, gl_TexCoord[0].xy).rgb);
vec3 ao = texture2D(AmbientOcclusionMap, gl_TexCoord[0].xy).rgb;
vec4 ambient = vec4(0.0);
vec4 diffuse = vec4(0.0);
vec4 specular = vec4(0.0);
vec3 ntView = normalize(tView);
for(int i = 0; i < NumLights; i++)
if (gl_LightSource[i].position.w == 0.0)
DirectionalLight(i, tPosition, ntView, texNormal, ambient, diffuse, specular);
else if (gl_LightSource[i].spotCutoff == 180.0)
PointLight(i, tPosition, ntView, texNormal, ambient, diffuse, specular);
else
SpotLight(i, tPosition, ntView, texNormal, ambient, diffuse, specular);
//Linear fog calculation
float dist = abs(vPosition.z);
float fogFactor =(gl_Fog.end - dist) * gl_Fog.scale;
fogFactor = clamp(fogFactor, 0.0, 1.0);
vec4 color = (ambient * gl_FrontMaterial.ambient + diffuse * gl_FrontMaterial.diffuse) * albedo; //Albedo
color = color + (specular * gl_FrontMaterial.specular);//Spec
//color = color * vec4(ao,1.0);
color = mix( gl_Fog.color, color, fogFactor); //Fog
gl_FragColor = color;
Thanks. I think the problem is with your normal map lookup code. The texture color values range from 0 to 1. However, the normals need to range from -1 to 1. Also, it appears the green channel in your normal map is flipped. Try modifying your normal map lookup to the following:
vec3 texNormal = normalize(texture2D(NormalMap, gl_TexCoord[0].xy).rgb * 2.0 - 1.0) * vec3(1.0,-1.0,1.0); |
Wow, I must have hit undo at some point in my code because I remember renormalizing the normal map from -1 to +1 ... but it sure isn't in that code...
I'll give your tips a try. Not sure why the green channel is flipped, I'll look into that as well. Thanks for your great support, ~George |
| Tags |
| binormal, normal, tangent |
| Thread Tools | |
| Per vertex attributes in OTF objects? | stefs | Vizard | 1 | 10-23-2009 03:36 PM |
| Semi-circle array containing target and distractor objects | ptjt255 | Vizard | 3 | 08-04-2009 03:09 AM |
| Normal Map Workflow for Vizard | shivanangel | Vizard | 2 | 03-10-2009 06:54 PM |
| Could not find plugin to load objects... | halley | Vizard | 1 | 05-30-2006 11:01 AM |
