The only way I can think of, is to create thin walls at the edges of the viewpoint (and just out of view, or invisible), update these walls with the mainview, and check for collisions with these walls.
Try viz.MainWindow.isCulled(node) to check if it is in the visible range or not. It will however not check if if is occluded or not.
| Thread Tools | |
| Display Modes | Rate This Thread |
| How to render a texture of the transparent object and then blur it | whj | Vizard | 1 | 09-25-2012 04:15 PM |
| AMD graphics hardware seems not to preload object | sleiN13 | Vizard | 2 | 03-20-2012 07:08 AM |
| Remove link and have object drop/collide? | cgibb | Vizard | 6 | 03-02-2010 05:18 PM |
| retrieve Object names | Geoffrey | Vizard | 11 | 12-11-2009 05:26 AM |
| rotate to object | jargon | Vizard | 1 | 08-08-2005 01:20 PM |
