The best resource for troubleshooting the connection of your Emagin display with Windows is the Emagin support team. Once Windows recognizes the device properly if you have any issues interfacing with Vizard, let us know and we can help.
I've tried to get the Z800 working on a 64 bit OS but never succeeded. Emagin support is minimal to none existing. Only solution I found was switching back to a 32 bit version of windows 7. You also need to run Vizard with administration rights to let the plugin function correctly. I've also have a custom build z800 vizard plugin but I'm not sure anymore if this was because I needed some extra functionality or the vizard plugin didn't work correctly. The emagin SDK pdf should provide enough information if you need to write your own plugin.
I contacted eMagin support about a year ago, and they said their tracker driver does not support 64-bit versions of Windows.
| Tags |
| emagin z800 |
| Thread Tools | |
| eMagin HMD Quad buffer problem | Shay | Vizard | 1 | 11-30-2012 12:00 PM |
| emagin z800 3D display | shahramy | Vizard | 1 | 01-11-2012 04:04 AM |
| Emagin Z800 | sleiN13 | Vizard | 8 | 01-07-2012 06:47 AM |
| emagin Z800 | hyde | Vizard | 1 | 09-21-2011 02:06 AM |
| Emagin Z800 problem | michaelinTX | Vizard | 5 | 07-12-2007 05:18 AM |
