Old 01-24-2013, 08:11 PM
You can use the viz.addBlankTexture command to create 3D textures with a specified depth. Here is a sample script showing how to load images into each depth slot:
#Create list of 2D images that will make up 3D texture
files = [ 'launch_stills/sts90launch'+ str(i+1) + '.jpg' for i in range(31) ]
#Create blank 3D texture
tex = viz.addBlankTexture([64,64,len(files)],viz.TEX_3D,minFilter=viz.LINEAR_MIPMAP_LINEAR)
#Load each image into 3D texture
for i,f in enumerate(files):
	tex.load(f,i)
#Apply texture to quad
quad = viz.addTexQuad(pos=(0,1.8,2),texture=tex)
#Create slider to change z texture coordinate of quad
slider = viz.addSlider(pos=(0.5,0.1,0))
def SetDepth(pos):
	m = viz.Matrix.translate(0,0,pos)
	quad.texmat(m)
vizact.onslider(slider,SetDepth)
viz.startlayer(viz.QUADS)
#Lower left
viz.texcoord(0,0,0)
viz.vertex(0.4,0.01,0)
#Upper left
viz.texcoord(1,0,0)
viz.vertex(0.4,0.05,0)
#Upper right
viz.texcoord(1,0,1)
viz.vertex(0.6,0.05,0)
#Lower right
viz.texcoord(0,0,1)
viz.vertex(0.6,0.01,0)
otf = viz.endlayer(parent=viz.SCREEN,texture=tex)
Hope this clears things up.
Old 01-25-2013, 11:27 AM
Question
#Edit - Still get the same problem on a Quadro 6000 with JPG or PNG
Unfortunately, I am still running into the same error, even when I copy and paste in your code.
I made a small subset of jpg images to see if there was a problem with the png format, and I still encounter the following error.
** ERROR: 'BodyScans/Test/3.jpg' cannot be loaded into depth 1 of 3D texture. Valid range is 0-0
** ERROR: 'BodyScans/Test/4.jpg' cannot be loaded into depth 2 of 3D texture. Valid range is 0-0
** ERROR: 'BodyScans/Test/5.jpg' cannot be loaded into depth 3 of 3D texture. Valid range is 0-0
** ERROR: 'BodyScans/Test/6.jpg' cannot be loaded into depth 4 of 3D texture. Valid range is 0-0
Do you happen to know what the error is exactly referring to for the 0-0 range?
I end up just having the first texture applied to the object.
I am developing on a laptop using an NVIDIA GTX 675M.
Are 3D Textures not be supported on these cards? Couldn't find any documentation only
I'll give it a shot on a Quadro in a few minutes.
Thank you,
George
Old 01-25-2013, 11:32 AM
Can you post the copy/pasted code you are running? Your original code sample was not using viz.addBlankTexture to create the 3D texture and specify the depth dimension.
Old 01-25-2013, 11:36 AM
I am now using your code and I still get the same error.
Only difference is I change the images being used to a different directory.
files = [ 'BodyScans/Test/'+ str(i+1) + '.jpg' for i in range(1,6) ]
tex = viz.addBlankTexture([512,512,len(files)],viz.TEX_3D, minFilter=viz.LINEAR_MIPMAP_LINEAR)
	tex.load(f,i)
def SetDepth(pos):
	quad.texmat(m)
#Lower left
viz.texcoord(0,0,0)
#Upper left
viz.texcoord(1,0,0)
#Upper right
viz.texcoord(1,0,1)
#Lower right
viz.texcoord(0,0,1)
Old 01-25-2013, 11:55 AM
What version of Vizard are you using? And to be clear, do you get any errors if you run the original script I posted, without any changes?
Old 01-25-2013, 11:59 AM
I'm running 4.06.0138
I get no errors with your code.
Old 01-25-2013, 12:08 PM
Can you run the following script and post the entire output?
tex = viz.addBlankTexture([512,512,len(files)],viz.TEX_3D)
print tex.getSize()
	tex.load(f,i)
viz.tex_3d
Avatar texture swaping sleiN13 Vizard 5 06-24-2011 01:48 AM
how I can get my texture to appear exactly as is defined mspusch Vizard 1 04-23-2005 01:12 PM
