Old 05-16-2005, 11:33 AM
tommahhh tommahhh is offline
loading large wav files in vizard
I was wondering what the best way to handle loading large .wav files would be. I am using around 100MB .wav files and I need to use the files for lip movement for some avatars. Can I used compressed files? Should I try to just clean up the files, reducing the size by as much as I can? Other suggestions?
Tom
Old 05-16-2005, 03:23 PM
Are you currently having problems using large wav files? The lip flapping functionality only works with wav files, so you can't compress. There's really not much else you can do. Let me know if you are having a specific problem using large wav files.
