Old 01-15-2013, 11:47 AM
OK, after playing around with peoplemaker, I managed to select the correct neckvertices and export a correct .vzf file. Two problems left:
- how to make the head of the original avatar invisble (the code from the peoplemaker help file does not work)
- if I put the custom head on the avatar, my head has a slight offset in it's pitch. Do I have to offset the neckbone to correct for that, or is there a more elegant way to fix this?
3dmenow, custom head, facegen, peoplemaker
Problems with imported Facegen head Don Vizard 1 11-04-2011 01:27 AM
Awkward neck/shoulder connection when adding custom head to vcc model. vEsotu Vizard 5 10-09-2008 05:07 PM
adding heads to custom avatars vAlexia Vizard 5 02-13-2007 11:14 AM
problems adding a custom morph head to a custom body Greenwu Vizard 1 07-27-2006 10:32 AM
Creating Custom Avatar Heads farshizzo Vizard 22 09-12-2004 09:23 PM
