Old 01-14-2013, 08:48 AM
pankaj bansal pankaj bansal is offline
Object Manipulators
Hii
I am working on some project using vizard and I need the functionality of object manipulators. What I mean is when I select a model, Some manipulators should appear which will give me functionality of scaling,rotating and translating the model. Like there are manipulators in all 3D applications like 3dsmax, Delta3D. Even OSG has a dragger manipulator which gives functionality of translating. So is there something like that in vizard....
If not available in vizard, I have implemented a manipulator in osg. I think vizard is based on osg and uses its plugins. Can there be any method that I can use that implementation by making some plugins.....
Regards
Pankaj Bansal
manipulator, object
AMD graphics hardware seems not to preload object sleiN13 Vizard 2 03-20-2012 07:08 AM
Making an object to appear after other object done animating jaylocco Vizard 2 07-13-2009 07:17 PM
rotate to object jargon Vizard 1 08-08-2005 01:20 PM
