Old 01-11-2013, 11:26 AM
The reason your script does not behave properly is because it is not setting up any link between the head tracker and the main viewpoint. As I mentioned previously, the CaveView class is used to setup such a link. If you don't need the magic carpet functionality, then simply ignore the cave_origin object, which defaults to [0,0,0] anyway. Adding the following code to your script should fix the issue:
vizcave.CaveView(viewTracker)
If you insist on not using the CaveView class, then you can manually create the link between the head tracker and main view using the following code:
viz.link(viewTracker,viz.MainView,mask=viz.LINK_POS)
Both the code snippets above are functionally equivalent. The CaveView class just provides the added magic carpet functionality, which is purely optional.
Any working 3D Vision - quadro systems? Jerry Vizard 0 10-20-2010 01:19 PM
Properly aligning the intersense with the PPT Systems Z Axis shivanangel Precision Position Tracker (PPT) 0 11-10-2009 12:35 PM
CAVE, navigation, tracked wand, coordinate systems JimC Vizard 6 10-09-2009 01:43 PM
creating multiple coordinate systems and making them visible jalvarez Vizard 1 02-27-2009 01:36 PM
Transforming coordinate systems. v-Salik Vizard 1 09-19-2007 08:45 PM
