Old 10-05-2012, 09:14 AM
IGM IGM is offline
DATAGLOVE in AVATAR
Hi, I would like to move fingers of the avatar with data from a DATAGLOVE. Someone knows How could I do?
I know to move a hand model but not the fingers of the avatar.
Thank you very much.
Old 10-05-2012, 03:29 PM
mspusch mspusch is offline
which glove do you use and which avatar model?
one way to do this is to use the glove with Motionbuilder (most glove companies provide a Motionbuilder plug-in) and then use Vizard Live Characters.
this requires Autodesk Motionbuilder and then the Worldviz Live Characters plugin
all best,
Matthias
Old 10-08-2012, 05:37 AM
IGM IGM is offline
Hi Matthias,
I have a 5DT Dataglove and I want to animate the hand of vcc_male of Vizard, without Autodesk Motionbuilder.
It is possible?
Thank you very much
Old 10-08-2012, 11:49 AM
Yes, this should be possible. Does the following work for you?
avatar = viz.add('vcc_male.cfg')
PORT_5DT_USB = 0 #Connect to first USB device
rightGlove = viz.add('5dt.dls')
import hand
rhand = hand.AvatarHandModel( avatar, sensor = rightGlove )
#lhand = hand.AvatarHandModel( avatar, sensor = sensor, left = True )
Old 10-09-2012, 03:32 AM
IGM IGM is offline
It works very well.
Thank you very much!
Old 10-16-2012, 03:36 AM
IGM IGM is offline
Hello!
Someone knows if it's possible some kind of calibration of 5dt DATAGLOVE in vizard?
Thanks!
avatar, dataglove, fingers
Avatar & Motion Capture Interface Angie Vizard 1 08-05-2010 07:17 PM
Collision of an avatar with a quad Frank Verberne Vizard 8 06-04-2008 10:44 AM
Looking through the eyes of an avatar Frank Verberne Vizard 2 04-01-2008 06:52 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
