This seems to indicate that the 32-bit OpenHaptics 3.0 binaries (i.e. hd.dll and hl.dll) were not installed properly. Even if you are running on a 64-bit system, you still need the 32-bit binaries, since Vizard is a 32-bit application.
You might need to double check with SensAble to make sure their 64-bit installer still supports 32-bit applications. |
If I'm now using two devices, how do I determine what the names are?
For instance, previously I could use one device with the following code: Code:
device = sensable.addHapticDevice() I have tried, Left, Right, left, right, 1,2, and 3 and unfortunately I cannot connect. Thanks |
| Thread Tools | |
| Creating a Vizard Sensor Plugin | farshizzo | Plug-in development | 25 | 08-01-2019 12:24 AM |
| Sensable Open Haptics-"Failed to load plug-in: 'sensable3.dle'" | mhead10 | Vizard | 2 | 09-04-2012 01:40 PM |
| Could not find plugin to load objects... | halley | Vizard | 1 | 05-30-2006 11:01 AM |
