Old 09-21-2012, 11:38 AM
mhead10 mhead10 is offline
THANKS for fixing my dumb mistake! The name was changed.
Old 09-21-2012, 12:07 PM
I just restarted my computer and the error came back
Anymore thoughts? The error seems to be coming from the
device = sensable.addHapticDevice()
If I comment it out I get no error. I'm now leaving it blank because I want the default haptic device object to be connected.
Old 09-22-2012, 04:45 AM
I uninstalled and reinstalled Open Haptics 3.0 x64 onto my Windows 7 64-bit system. Now I just get the following error:
** ERROR: Failed to load plug-in: 'sensable3.dle'
this in turn creates the following as well
AttributeError: 'VizExtension' object has no attribute 'addHapticDevice'
I get the same errors with all variation of O.H.'s 3.0 and 2.0. I'm guessing for some reason O.H.'s 3.0 can't be found because I know it's installed. My control panel shot is attached.
Any guesses why Vizard thinks Open Haptics isn't installed?
Old 09-24-2012, 11:33 AM
This seems to indicate that the 32-bit OpenHaptics 3.0 binaries (i.e. hd.dll and hl.dll) were not installed properly. Even if you are running on a 64-bit system, you still need the 32-bit binaries, since Vizard is a 32-bit application.
You might need to double check with SensAble to make sure their 64-bit installer still supports 32-bit applications.
Old 09-25-2012, 10:29 AM
To make a long story short, I finally found using the newest driver from SensAble's website (4.2.133) instead of what comes packaged with Open Haptics 3.0 (4.2) fixed my problem.
Thanks for your help farshizzo
Old 10-06-2012, 09:57 AM
If I'm now using two devices, how do I determine what the names are?
For instance, previously I could use one device with the following code:
However, now I'm using two devices, and thus need to figure out what their names are. Therefore, how do you determine the names? Where are the names assigned? Is this a guess and check method?
I have tried, Left, Right, left, right, 1,2, and 3 and unfortunately I cannot connect.
Creating a Vizard Sensor Plugin farshizzo Plug-in development 25 08-01-2019 12:24 AM
Sensable Open Haptics-"Failed to load plug-in: 'sensable3.dle'" mhead10 Vizard 2 09-04-2012 01:40 PM
