Old 09-21-2012, 11:32 AM
mhead10 mhead10 is offline
import ctypes
import numpy
import viztask
import time
import threading
nidaq = ctypes.windll.nicaiu # load the DLL
int32 = ctypes.c_long
uInt32 = ctypes.c_ulong
uInt64 = ctypes.c_ulonglong
float64 = ctypes.c_double
TaskHandle = uInt32
read = int32()
# the constants
DAQmx_Val_Cfg_Default = int32(-1)
DAQmx_Val_Volts = 10348
DAQmx_Val_Rising = 10280
DAQmx_Val_FiniteSamps = 10178
DAQmx_Val_ContSamps = 10123
DAQmx_Val_GroupByChannel = 0
DAQmx_Val_GroupByScanNumber= 1 #interleaved
# initialize variables
taskHandle = TaskHandle(0)
max_num_samples = 2
data = numpy.zeros((max_num_samples,),dtype=numpy.float64 )
print
def CHK(err):
if err < 0:
buf_size = 100
buf = ctypes.create_string_buffer('\000' * buf_size)
nidaq.DAQmxGetErrorString(err,ctypes.byref(buf),bu f_size)
raise RuntimeError('nidaq call failed with error %d: %s'%(err,repr(buf.value)))
#Main Program
CHK(nidaq.DAQmxCreateTask("",ctypes.byref(taskHand le)))
CHK(nidaq.DAQmxCreateAIVoltageChan(taskHandle,"Dev 2/ai0:1","",DAQmx_Val_Cfg_Default,float64(-13.0),float64(13.0),DAQmx_Val_Volts,None))
CHK(nidaq.DAQmxCfgSampClkTiming(taskHandle,"",floa t64(1),DAQmx_Val_Rising,DAQmx_Val_ContSamps,uInt64 (max_num_samples))); #(samples/sec/channel) #ContSamps
CHK(nidaq.DAQmxStartTask(taskHandle))
# stop/clear when I want to end program by mouseclick
def onMouseDown(button):
CHK(nidaq.DAQmxStopTask(taskHandle))
CHK(nidaq.DAQmxClearTask(taskHandle))
viz.callback(viz.MOUSEDOWN_EVENT,onMouseDown)
def obtain_value():# continuosly read the DAQ values
CHK(nidaq.DAQmxReadAnalogF64(taskHandle,1,float64(-1),DAQmx_Val_GroupByChannel,data.ctypes.data,max_n um_samples,ctypes.byref(read),None))
print data
x=0
def loop(): # loop which call for DAQ values to continuosly be read
while x < 10:
obtain_value()
viz.director(loop)
viz.clearcolor(1,0,0) #proves I can use vizard interface with continuous data aquisition
# add haptics
sensable=viz.add('sensable3.dle')
device = sensable.addHapticDevice(name = 'Left')
device.workspace.setScale([100,100,100])
device.workspace.setPosition([0,0,0])
[/CODE]
Old 09-21-2012, 11:35 AM
Are you sure Left is the correct name of the device? If not, leave the name blank, and the plugin will connect to the default device. If you only have one device connected, then you really don't need to specify a name. Try this instead:
device = sensable.addHapticDevice()
Old 09-21-2012, 11:38 AM
THANKS for fixing my dumb mistake! The name was changed.
Old 09-21-2012, 12:07 PM
I just restarted my computer and the error came back
Anymore thoughts? The error seems to be coming from the
If I comment it out I get no error. I'm now leaving it blank because I want the default haptic device object to be connected.
Old 09-22-2012, 04:45 AM
I uninstalled and reinstalled Open Haptics 3.0 x64 onto my Windows 7 64-bit system. Now I just get the following error:
** ERROR: Failed to load plug-in: 'sensable3.dle'
this in turn creates the following as well
AttributeError: 'VizExtension' object has no attribute 'addHapticDevice'
I get the same errors with all variation of O.H.'s 3.0 and 2.0. I'm guessing for some reason O.H.'s 3.0 can't be found because I know it's installed. My control panel shot is attached.
Any guesses why Vizard thinks Open Haptics isn't installed?
Old 09-24-2012, 11:33 AM
This seems to indicate that the 32-bit OpenHaptics 3.0 binaries (i.e. hd.dll and hl.dll) were not installed properly. Even if you are running on a 64-bit system, you still need the 32-bit binaries, since Vizard is a 32-bit application.
You might need to double check with SensAble to make sure their 64-bit installer still supports 32-bit applications.
Old 09-25-2012, 10:29 AM
To make a long story short, I finally found using the newest driver from SensAble's website (4.2.133) instead of what comes packaged with Open Haptics 3.0 (4.2) fixed my problem.
Thanks for your help farshizzo
Creating a Vizard Sensor Plugin farshizzo Plug-in development 25 08-01-2019 12:24 AM
Sensable Open Haptics-"Failed to load plug-in: 'sensable3.dle'" mhead10 Vizard 2 09-04-2012 01:40 PM
