Old 08-14-2012, 09:01 AM
Originally Posted by victorqx View Post
I did consider using the vizhtml module, but at the moment I'm using a top projection on the tablet to show a floor plan of the current scene. I like this floor plan quite a bit and assume that it would be quite a lot of work to supply this in the vizhtml module. Therefore I would like to stick with running the Vizard cluster client.
Is the floor plan a static image? If so, then it should be straightforward to provide this to the web browser using the HTML image tag.
I assume that mouse events are not supported in this manner (otherwise you would have lead me towards a solution
There is currently limited functionality for handling some keyboard/mouse events from the cluster clients. However, I'm assuming for your application you would need mouse move events, which is currently not supported. This will be added to the next release though.
Events in a cluster jlesquembre Vizard 2 11-16-2011 05:03 PM
Mouse bug in V3 and V4 Renato Lima Vizard 2 05-11-2011 06:38 PM
assigning the mouse functionality to Keyboard events jaffaaswami Vizard 2 10-07-2010 10:58 PM
assigning the mouse functionality to Keyboard events jaffaaswami Vizard 0 10-06-2010 06:49 AM
Cluster Client Timeout after 10s... k_iwan Vizard 5 02-22-2007 01:56 PM
