Old 08-14-2012, 09:55 AM
The vrpn objects have a getSampleNumber() and getSampleTime() method for retrieving the number/time of the last received sample. You could setup a timer to check these values and trigger an event if they haven't changed for over 10 seconds.
Old 08-14-2012, 10:17 AM
nabrahamson nabrahamson is offline
I've considered this route, but since they don't trigger until the kinect detects another user, it's not really the solution I am going for. In this scenario, the kinect can be plugged in and communicating with FAAST, but there is no user in front of it. The result is a false positive since the two functions mentioned will return 0 and 0.0 even when there is a kinect plugged in and recognized by the system.
Is there a way to catch what vizard is printing to the console? If I had the ability to do that, then I could watch for VRPN Errors, that are being printed out.
Old 08-23-2012, 12:01 PM
That error message is printed deep within the VRPN source. I'm not aware of any way to programmatically detect it, other than modifying the VRPN source.
Old 04-24-2013, 03:03 PM
pankaj bansal pankaj bansal is offline
@nabrahamson
Hey I want to ask if you were able to do this. I also want to do the same and have not find a solution yet..
regards
Pankaj bansal
vrpn
VRPN quaternion conversion from PPT from Intersense InertiaCube willemsn Precision Position Tracker (PPT) 0 07-20-2011 02:59 PM
VRPN info sdiverdi Precision Position Tracker (PPT) 5 01-16-2011 01:00 PM
The problem of tracker using via VRPN _kj_ Vizard 2 08-13-2009 01:03 AM
Does the vrpn7.dle tracker plug-in clear the udp buffer? michaelrepucci Vizard 2 09-19-2008 11:22 AM
swapPos and swapQuat with VRPN michaelrepucci Vizard 1 07-29-2008 12:27 PM
