Old 07-26-2012, 03:03 PM
saajaja saajaja is offline
Scaling avatar meshes
I am trying to scale an avatar's head and body separately. I have the Complete Characters DVD set and I am working with casual15_f_highpoly.cfg as an example.
When I do this:
c1 = viz.addAvatar('6F/casual15_f_highpoly.cfg ')
c1.disable(viz.LIGHTING)
print c1.getChildren()
print 'Model contains the following scene graph nodes:'
for name in c1.getNodeNames():
    print ' ',name
c1.getChild('casual15_f_highpoly01.CMF').setScale(2, 2, 2)
I get this:
Loading File: 6F/loadMe.cfg
  casual15_f_highpoly.CMF
** ERROR: Could not find child with name 'casual15_f_highpoly01.CMF'
However, this does make the body invisible:
c1.visible(viz.OFF, 'casual15_f_highpoly01.CMF')
Help is appreciated.
Old 07-30-2012, 08:04 PM
I don't think the subchild returned is a node3D object that you can scale and call most node3D commands on. It's more like a texture that can be modified in terms of visibility and alpha. If you want to scale the head the best would be to to this in 3ds Max and re-export the meshes. That way you could also adjust the neck of the body mesh. Another option would be to create a Peoplemaker head that you could scale in Vizard.
Old 08-24-2012, 12:17 PM
I wanted to have the option of scaling the body to arbitrary sizes while keeping the head from looking weird by scaling it separately. But it's okay. I can just make a copy of the avatar, turn off the head's visibility on one, turn off the body's visibility on the other, and scale them separately.
Avatar & Motion Capture Interface Angie Vizard 1 08-05-2010 06:17 PM
avatar scale and link.setpos conflict? sircedric4 Vizard 0 09-29-2009 07:48 AM
Collision of an avatar with a quad Frank Verberne Vizard 8 06-04-2008 09:44 AM
Looking through the eyes of an avatar Frank Verberne Vizard 2 04-01-2008 05:52 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 08:48 AM
