Old 07-16-2012, 01:03 AM
sleiN13 sleiN13 is offline
Bulk loading avatars
Is there a way to load a large amount of avatars efficiently?
I've to load 80 avatars into memory to be used in the virual world (not all are shown at the same time) but found that loading times increase almost exponentially.
I found that loading avatars in realtime will produce a significant framedrop (same goes for loading animations on demand) so I've to load them all at startup. but this takes a lot of time and I was wondering if there was a faster way of loading them for example in 1 bulk file or something.
Old 07-16-2012, 01:31 AM
Are these 80 distinct avatars? If you have copies of the same avatar you can use the node3D.copy command to save loading time.
Old 07-17-2012, 01:42 AM
They are all 80 unique avatars
Old 07-17-2012, 03:14 AM
You could modify the avatar cfg files so only the animations being used are loaded. This should save some loading time.
Error when loading a lot of avatars dan12345 Vizard 7 07-28-2008 04:24 AM
avatars dig Vizard 4 09-20-2007 03:29 PM
Avatars in an array and link/unlink betancourtb82 Vizard 7 09-05-2006 04:06 PM
loading motion data for avatars dellatails Vizard 2 02-13-2006 12:51 PM
loading anacapa avatars? shai Vizard 3 04-24-2005 05:36 PM
