Old 07-12-2012, 01:51 PM
DillonB DillonB is offline
Actually, I was looking through some more documentation and I had just tried that. I updated my code so that now it looks like this (difference begins at line 22):
#	WorldViz Copyright 2002										#
#  This script demonstrates how perform grab the raw data 		#
#  from the head tracker plugin.								#
viz.setMultiSample(4)
viz.fov(60)
import vizinfo
vizinfo.add('This script demonstrates how to perform manual head tracking.\nIt will retrieve data from the tracker and only rotate the yaw.\nBy default this script will connect to an intersense.\nPress the \'r\' key to reset the tracker')
#Add environment
viz.addChild('gallery.osgb')
InertialLabs = viz.add('InertialLabs.dle')
sensors =InertialLabs.addSensorBus(workset=0,port=5)
# Get handle to first sensor
sensor1 = sensors[0]
def updateView():
    #pos = sensor.getPosition()
    euler = sensor.getEuler()
    #viz.MainView.setPosition([pos[0], pos[1]+1.82, pos[2]])
    viz.MainView.setEuler(euler)
    print euler
vizact.ontimer(0,updateView)
However, I get this error:
File "<string>", line 11, in <module>
File "C:\Users\dbak\Documents\vizard-programs\Vizard1.py", line 21, in <module>
sensors = InertialLabs.addSensorBus(workset=0,port=5)
AttributeError: '_InertialLabsExtension' object has no attribute 'addSensorBus'
In summary, I am in fact using a sensor bus, but the addSensorBus method is not working for me.
headtracking
Creating a Vizard Sensor Plugin farshizzo Plug-in development 25 08-01-2019 01:24 AM
Unusual tracker sensor setup with Vizard Zhi Vizard 2 06-12-2012 10:52 AM
sensor or not sensor? nige777 Vizard 0 03-29-2011 05:03 AM
wiimote and sensor bar masaki Vizard 1 03-06-2008 04:07 PM
Multiple Copies of same sensor plugin RedSpikeyThing Plug-in development 2 02-12-2008 03:10 PM
