Reduce the polygon count, most of the time that is more effective then reducing texture size. Use the F4 key to see if you reached your gpu memory limit to make sure it isn't the textures. Besides that you could also make rows of shelves invisible if you can't possibly see them anyway. Vizard should be doing this automatically with culling but cull takes time and therefore frame rate.
Very good tip. My frame rate is high again! Thanks.
| Thread Tools | |
| Lighting for a new Scene | jassel41 | Vizard | 2 | 11-10-2010 10:14 PM |
| How to vary the transparency of the scene | whj | Vizard | 2 | 04-04-2010 09:16 PM |
| Warping Rendered Scene? | rwgray | Vizard | 3 | 03-25-2010 03:19 PM |
| Copying Scene? | Brett Lindberg | Vizard | 0 | 08-29-2009 12:56 AM |
| Problems loading WRL file | DrunkenBrit | Vizard | 2 | 01-29-2009 01:58 AM |
