Old 06-16-2012, 01:48 PM
mspusch mspusch is offline
We at Worldviz have successfully used the Inertia Cube 2+ or 3 for many years (but that requires a serial connector, any connection over USB always has a little bit of 'stutter' in there for head orientation).
I know that some customers of ours are using Trivisio Colibri 3DOF, which seems to work (but i have never personally tried it for longer times).
RE Motionnode, i have not seen this used personally for a head tracked immersive system from all i know.
There are some more possibilities that just the three you named, it might be good if you sent a message to 'sales@worldviz.com'.
also, just so you know, Worldviz can resell almost any VR gear out in the market, so you can also purchase thru us if you want, then we'll make 100% sure that your sensor was tested with Vizard before you receive it.
have fun!
Intersense wand and Head tracker blessonisaac Vizard 0 01-10-2011 03:39 PM
cant read head tracker from hmd Darkmax Vizard 0 03-05-2010 12:09 PM
The problem of tracker using via VRPN _kj_ Vizard 2 08-13-2009 12:03 AM
Simple Head Tracker PHart Vizard 1 05-10-2009 05:35 PM
Awkward neck/shoulder connection when adding custom head to vcc model. vEsotu Vizard 5 10-09-2008 05:07 PM
