Old 06-19-2003, 11:07 AM
david david is offline
switching between scenes
hello,
I am trying to switch between different scenes in vizard but even with the very basic following lines I do not see anything on the screen. What is the correct way to use the setscene command?____________________________
viz.setscene(1)
a = viz.addchild('tut_sphere.wrl',1)
David
Old 06-19-2003, 11:20 AM
Hi David,
The second argument of the addchild command is the anchor, the third argument is the scene. So in your case you need to do
a = viz.addchild('tut_sphere.wrl',viz.WORLD,1)
Hope that helps,
Farshid
Old 06-19-2003, 11:26 AM
Hi farshid,
Thanks for your answer, I did not know that the [anchor] argument was necessary
David
Old 07-01-2003, 12:02 PM
Unhappy Can't use a scene number higher than 2
BTW,
I tried using scene number between 3 and 6 but vizard simply crashes... Any thoughts?
David
Old 07-01-2003, 06:05 PM
mspusch mspusch is offline
Hi David,
Sorry about that. It is already fixed in the newest version.
