Old 05-14-2012, 05:17 AM
new_horizon new_horizon is offline
Slider Assistance
Hi All,
I'm currently working on incorporating a slider into my work.
A few questions...
1) Is there a way of labelling different areas of the slider for the user? I have already specified the different intervals in the code.
2) Is there a way of outputing the slider value from the code? So in trial 1 for instance, where did the user move the slider to when prompted.
Old 05-14-2012, 06:48 AM
1) Do you want labels above or below the slider? If so, you can create text objects and position them at those intervals.
2)Register a callback function for the slider event using vizact.onslider:
slider = viz.addSlider(pos=[0.5,0.5,0])
def sliderChanged( pos ):
    print pos
vizact.onslider( slider, sliderChanged )
Old 05-14-2012, 07:30 AM
Hi Jeff,
Thanks for your prompt response.
I have been trying this method and it does not seem to allow me to register the slider position as a variable for an output.
How can I assign the "pos" value to a variable? For instance, "slidepos"?
Old 05-16-2012, 07:32 AM
I'm not sure I understand the question. Can you post some example code that shows what you are trying to do?
Detect a double click on a gui slider Renato Lima Vizard 4 11-09-2010 02:23 PM
adding more than 1 action for avatar animation slider control yak Vizard 0 07-21-2009 11:22 AM
help with slider code yak Vizard 2 07-20-2009 12:12 PM
Vizmenu slider bug? Gladsomebeast Vizard 2 10-22-2008 08:05 PM
Blending/Fading 5 Textures with a Slider south_bank Vizard 2 05-15-2008 07:59 AM
