Old 04-27-2012, 04:08 AM
Ploep Ploep is offline
3D world editor
Im creating a 3D world editor with Vizard. I want to add a model, place it and be able to replace the models. The user can navigate through the world with wasd and click a model and replace it. So far so good, but i'm experiencing some problems with the object placement.
This is the code for a model to follow the mouse-cursor:
		# draw model on mouse position
		if(self.isDrawing):
			line = viz.MainWindow.screenToWorld(viz.mouse.getPosition())
			x,y,z = line.endFromDistance(6)
			y = 0
			self.model.setPosition([x,y,z])
It works but it is still hard to navigate objects in the world. Is there a better way to let models follow the mouse and put them in the 3D world?
Thanks!
Old 05-01-2012, 07:52 AM
You could try using a viztracker.MouseTracker. Here's a simple example:
import viztracker
gallery = viz.addChild('gallery.osgb')
ball = viz.addChild('soccerball.osgb')
#Move the object with mouse movements and mousewheel
mousetracker = viztracker.MouseTracker()
link = viz.link(mousetracker,ball)
#Disable the link and place the object with a mousepress
vizact.onmousedown(viz.MOUSEBUTTON_LEFT, link.disable)
viz.mouse(viz.OFF)
Old 05-03-2012, 03:25 AM
Thanks for your reply. I implemented the mousetracker and it is working better. When the user clicks the mouse i put the model on x,y=0,z so that the model is placed on the ground. I tried to catch a mouse_move event and set the position of the model to the ground so that the user can't move the object in the air or through the ground.
	def onMouseMove(self,e):
		if(self.isDrawing):
			x,y,z = self.model.getPosition()
			self.model.setPosition([x,0,z])
But this wont have any effect. Is it possible to adjust the mousetracker so that the models stick to the ground plane?
EDIT: I try to get some collision with the mousetracker model but I dont know how, can someone give me some hints? Thanks
World Transformations c4am95 Vizard 4 11-09-2010 01:50 PM
why is time faster in my virtual world? billjarrold Vizard 1 11-24-2009 06:33 PM
button in the world guxmy01 Vizard 1 06-10-2008 05:37 PM
What are the options for making a movie of a Vizard world? Karla Vizard 1 05-13-2008 11:56 AM
General Questions about Vizard: World Viz dav Vizard 5 08-28-2006 04:44 PM
