Old 02-15-2012, 03:37 PM
AySz88 AySz88 is offline
The code always does the following at the same time as calling <window>.ortho(). (Testing it just now, doing it just before or just after makes no difference.)
cave.setTracker(pos=None, ori=None)
view.setView(viz.NullLinkable) # disassociate CaveView and tracker
viz.cam.reset()
This should cause the cave object to stop calling <window>.frustum, correct?
Old 02-15-2012, 04:10 PM
That should stop the cave object from automatically changing the frustum. Try adding the following line as well:
viz.MainWindow.ipdVector(None)
I noticed the IPD values changes drastically from trial to trial. Are you sure this isn't causing the problem?
Old 02-15-2012, 04:24 PM
Yes - the center of the object is at the same distance as the screendistance used for the orthographic projection. Thus the square mark should always have zero disparity, so it shouldn't move no matter what the IPD is.
Does that line of code force the IPD value to zero? That wouldn't work for my purposes, since I do need stereo - it is adjusting the IPD value so as to "turn up" or "turn down" the stereo cue on demand, as needed by the rest of the experiment.
Old 02-15-2012, 05:13 PM
The IPD vector is used by vizcave to change the direction the IPD shift is applied to the view matrix. I think adding that line should fix your problem.
bug, heisenbug, orthographic, stereo
orthographic projection in a head-tracked cave environment michaelrepucci Vizard 5 12-14-2011 11:29 AM
vizcave and quad-buffered stereo michaelrepucci Vizard 7 11-29-2011 12:15 PM
Stereo Projection Moh200jo Vizard 3 06-10-2009 07:33 PM
Stereo problems on 3D monitor timbo Vizard 3 08-13-2008 03:07 PM
stereo projection issue asimbh Vizard 3 10-05-2007 11:22 AM
