Old 12-13-2011, 03:15 AM
Andy Andy is offline
I get an error if I try to set the MaskedContext to viz.CLIENT1 can you tell me why? I think the VizWindow instance isn't valid.
Old 12-13-2011, 01:03 PM
The previous code sample is incorrect. Try the following instead:
maze = viz.addChild('maze.osgb')
UpperLeftWindow = viz.addWindow(pos=(0,1.0),size=(0.2,0.4))
UpperLeftWindow.visible(0,viz.SCREEN)
BirdView = viz.addView()
#Attach the bird's eye view to the upper left window
UpperLeftWindow.setView(BirdView)
#Move the view above the center of the room
BirdView.setPosition([0,50,0])
#Rotate the view so that it looks down
BirdView.setEuler([0,90,0])
# Show the window only on client 1
UpperLeftWindow.visible(0)
with viz.cluster.MaskedContext(viz.CLIENT1):
	UpperLeftWindow.visible(1)
You still need to add the window to all machines, but just make it visible on one.
Question about cluster replacement mizutani_jun Vizard 1 02-18-2011 03:49 PM
Question about GUI and CLUSTER mizutani_jun Vizard 2 01-02-2011 04:35 PM
Tiling in a cluster setting vijaykiran Vizard 5 10-30-2009 12:41 PM
Cluster Help videcuk Vizard 12 09-21-2007 03:14 PM
quad_buffer cluster John P Vizard 4 06-07-2006 11:01 PM
