Old 12-07-2011, 08:23 AM
EnvisMJ EnvisMJ is offline
Level of Detail ranges from Max OSG exporter
I think I've finally to figure out how to get my Level of Detail models into Vizard (I think)
I'm having problems with the ranges that you can set for each in Max. Is there some sort of unit conversion that someone can explain?
I'm using 3 models, and I've determined that a range of 0-100 is too small and 0-1000 is to large. I've played around with it, but can't seem to get good ranges by trial and error.
Old 12-07-2011, 09:14 AM
The LOD ranges should represent distance to the viewpoint. The range units should match whatever units you are using in 3dsmax. If you think it's still not correct, can you provide us with the max model?
Old 12-07-2011, 10:55 AM
Ah, I think I may have it. We were scaling the model WAY down when bringing it into vizard so I think that was messing with the LoD ranges. I scaled it down, then exported it and I think it's working better.
rendering level shahramy Vizard 1 07-26-2010 12:12 PM
Level of Detail envisC Vizard 2 10-22-2009 12:07 PM
Big problem with OpenSG exporter for max to Vizard omadawn Vizard 5 06-09-2009 11:51 AM
cal3d exporter lqakane Vizard 0 03-02-2009 07:38 AM
At my Whits end with Cal 3D Exporter shivanangel Vizard 6 02-25-2007 03:00 PM
