Old 11-30-2011, 07:44 PM
1) Yes, this is possible:
import viztask
def changeFOV():
	yield viztask.waitKeyDown(' ')
	viz.fov(60)
viztask.schedule( changeFOV() )
2) You can check the distance between the viewpoint and each billboard using the vizmat.Distance command. The check can be done within a timer function on some regular interval. Based on the distance you can swap a new model in.
If you have access to Vizard 4 this can be accomplished using proximity sensors.
fov, objects, rendering
