a. You can scale movement using the <link>.postScale command:
tracker = vrpn.addTracker('PPT0@hostname',0)
link = viz.link(tracker,viz.MainView)
#Scale X and Z movement by a factor of 2
link.postScale([2,1,2])
link.postTrans([0,2,0]) |
Thanks!
I used this method, which solves the problems (although it needs extreme measures - I had to scale by [90,30,90]), but now I have odd jumps - on some fixed points, when I turn my head the view just jumps about 30-40 degrees to the left. about c: I meant that I could work with the PPT's coordinate system directly in the vizard. would make setting up scenes a whole lot simpler. |
It sounds like your model is still too large if you have to scale the movement by that amount.
The coordinate systems in Vizard and PPT are the same. If you're not scaling the movement in Vizard and you move one meter in PPT that will move the viewpoint one meter in Vizard. |
| Thread Tools | |
| Realistic Light and Shadows Using Vizard and 3DS Max | jde | Vizard | 4 | 07-13-2012 10:58 AM |
| Vizard 4 Beta Testing | farshizzo | Announcements | 0 | 02-01-2011 10:46 AM |
| Vizard 4 Beta Testing | farshizzo | Vizard | 0 | 02-01-2011 10:46 AM |
| .3DS importing in Vizard and 3D Studio | jde | Vizard | 1 | 08-28-2009 03:14 PM |
| Vizard tech tip: Using the Python Imaging Library (PIL) | Jeff | Vizard | 0 | 03-23-2009 11:13 AM |
