Old 11-10-2011, 08:28 AM
jlesquembre jlesquembre is offline
Events in a cluster
I'm running a cluster with several clients, all in the same computer.I have a problem with events, I want to make some actions if the user makes a click. If I click in the master window, everything is fine, but is not possible to make a click in any client window. Any suggestion?
Thanks.
Old 11-10-2011, 11:50 AM
Ok, I got it, I should use this code
def onmouse(button):
client = viz.cluster.getClient()
print 'Mouse pressed on client',client,'the button',button
viz.callback(viz.MOUSEDOWN_EVENT,onmouse,viz.ALLCL IENTS)
But next problem is, how can I pick an object in clientX? For master or client1 works, but for others clients not. Any idea why?
Old 11-16-2011, 05:03 PM
Clustering is not really meant to be used this way. Cluster clients don't actually execute any Python code. They just receive commands from the master to perform basic low-level commands (e.g. add objects, set position, etc...). Clustering is only meant to be used when you want to clone the output of a script with only slight changes (e.g. view offset, fov). Picking is not supported on the clients.
Question about cluster replacement mizutani_jun Vizard 1 02-18-2011 02:49 PM
Question about GUI and CLUSTER mizutani_jun Vizard 2 01-02-2011 03:35 PM
Problem with server Events vOliver Vizard 2 09-15-2010 02:21 PM
Cluster Help videcuk Vizard 12 09-21-2007 02:14 PM
quad_buffer cluster John P Vizard 4 06-07-2006 10:01 PM
