Old 10-21-2011, 01:08 PM
EnvisMJ EnvisMJ is offline
Realistic Glass Material
I'm working on a VR training simulator for medical use. We've got a lot of glass vials and IV bags (and a few windows) in the environment. So need to get as realistic of a glass material as we can manage.
An older version of the project an be seen here:
http://www.youtube.com/watch?v=x440QBi_xfQ
We're using LoD, baked lighting, normal maps and transparency maps. What's the best glass material we can manage in Vizard beyond just turning on the transparency?
Old 10-21-2011, 07:32 PM
If you are using 3ds Max and the OSG exporter you can replicate a glass material using a standard material with a diffuse texture with alpha channel. Use a circular alpha channel and Spherical Environment mapping coordinates in the material. This will give you a "fall off" opacity effect. You can add an environment map in the reflection slot . Attached is an example of the glass material.
3ds max, glass, material, realistic, transparent
Vizard and OBJ Material Files shivanangel Vizard 3 10-04-2013 07:11 AM
How to make a glass window in Vizard Frank Verberne Vizard 9 07-27-2011 04:47 PM
Cal3d material problem fracture Vizard 0 09-10-2009 02:58 AM
Unable to get material onto 3d Max avatar VDong Vizard 1 03-10-2009 12:45 PM
Glass (transparent materials) cantwelljm Vizard 1 03-08-2006 02:39 PM
