Old 10-04-2011, 04:01 PM
Within a function that gets called every frame you can get the tracker data as lists and extract the values you want to use. Something like the following:
def updateAvatar():
	pos=tracker.getPosition()
	ori=tracker.getEuler()
	avatar.setPosition([pos[0],0,pos[2]])
	avatar.setEuler([ori[0],0,0])
vizact.onupdate(0,updateAvatar)
Old 10-05-2011, 07:06 AM
Veronika Veronika is offline
I have this code:
#set main view (x,z,y)
viz.MainView.translate(0,2,-15)
viz.clearcolor(viz.GRAY)
#Connect to Patriot sensor
polhemus = viz.add('polhemus.dle')
patriot = polhemus.addPatriot()
avatar=viz.add('male.cfg')
#Link the hand to the Patriot data
viz.link(patriot,avatar)
def updateavatar():
pos=patriot.getPosition()
ori=patriot.getEuler()
avatar.setPosition([pos[0],0,pos[0]])
vizact.onupdate(0,updateavatar)
and I want to walk with avatar and if sensor is further from calibration place, the speed of walking is more. But this code for update avatar isn't function. I whole day try to set this, but I don't know how. Can you help me with this?
Old 10-05-2011, 12:59 PM
Try removing the line where the avatar is linked to the Patriot data. That link is overriding the update function.
Avatar walking + camera free look kovitch Vizard 2 08-08-2011 08:57 AM
avatar walking over a sequence of points IGoudt Vizard 1 10-16-2009 12:22 PM
avatar automatically runs animation after fading into view v-clizzin Vizard 1 10-14-2009 06:01 PM
Looking through the eyes of an avatar Frank Verberne Vizard 2 04-01-2008 06:52 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
